Date:    7-21-2009
Number of Hours:    3.00
Brief Description:    Worked on firewall
Fabricated and assembled the fuel filler tube tonight out of stainless steel. Some of these parts had to be bent in places that were difficult to bend, so my bend lines didn't turn out perfectly - but in the end, I'm satisfied with the result. Think I'll figure out a way to make this water tight with a drain hose so when I spill gas filling it up it will drain on the ground instead of inside the cockpit.
