Date:    7-2-2010
Number of Hours:    7.00
Brief Description:    Installed Dial-a-trim
Again, I had the day off from work so I completed the installation of the dial-a-trim along with more work on the cowl. I did fiberglass shut the whole I cut yesterday and cut another, smaller one in the right spot. Just took a lot of sanding to make it look good. I also added fiberglass to the front of the cowling, behind the prop. This was not easy as the fiberglass kept wanting to flow to the lowest point. I just kept on brushing t back up until it dried enough to stay in place. I’m sure I’ll have to add a bit of fill to make it match with the rest of the cowl. Image 1 shows the latest view of the cowl.
No major issues with the installation of the dial-a-trim. It seems to work as advertised.
