5-2-2010 |
5.00 |
Wiring the RDAC unit |
Today I began to connect all the inputs to the RDAC unit for the Enigma. It probably would have been easier if I would have mounted the RDAC unit down lower on the port side, because where it is now, the screw terminals for the wires on one side are a little tough to get to. When I started connecting the wires to the RDAC, I assumed that the front-most cylinder on the port side was # 1, but I was wrong (it’s #2). Number 1 is the back cylinder on the port side. I also had to un-wrap and then re-wrap the exhaust because I forgot to install the EGT probes before I wrapped the 2 into 1 exhaust. D’oh! Just need to finish a few of the temperature connections and tidy up the wires and then I can move on to the baffle. |
