5-20-2009 |
2.50 |
Riveted on the top aft skin on the right wing |
Riveted on the top aft skin of the right wing. Made sure that SNX-W20-01L will work on the right wing upside down, so now I have to make a trip to Sonex (60 miles) and pick up another W20-01L. Also received the shielded cable for the strobe, so I installed this cable and the wires for the position/nav lights and the landing lights. Ran the wires ahead of the main spar with grommets installed where the wires go through the ribs. Then I ran the Strobe cable through one hole and the wires for the other lights through another hole to keep some distance between the wires to reduce the possibility of the high-voltage strobe signal from interfering with the other lights. |
