Date:    5-2-2009
Number of Hours:    6.00
Brief Description:    Completed the Pitot and AOA ports
Was sick for the past week, wasn't able to work in the shop at all - was torture sitting around not able to do anything.
Anyway, completed the Pitot and Static port just like drawing W23 – instead of just buying a Pitot like I've seen others have done Thought this would be an easy thing to work on to get back into the swing. See picture 1
In addition, I plan to install the Stratomaster Enigma, and in the installation manual for the Enigma there are instructions for building an Angle Of Attact port which get connected to the Enigma exactly like the Pitot and Static port do. With this in mind, I simply copied how the Pitot and Static port are installed in the right wing for the Positive and Negative AOA port on the left wing. It seems pretty simple and will hopefully work well once it's 'calibrated'. See picture 2.
