Date:    4-9-2009
Number of Hours:    8.00
Brief Description:    Worked on the Right Main Spar
Worked on the right main spar today. The right side is going much better than the left side did, probably because of all the stuff I learned doing the left one. Also have gotten much better at installing the rivets correctly the first time. So far, I've had to replace only 2 or 3 percent of the rivets I installed today - much better.
