4-8-2009 |
3.00 |
Finished the Left Main Spar |
Completed the left main spar tonight. Also received the new larger rivets I ordered from Wicks. When I screwed up a few nights ago and inserted the 35 rivets the wrong way, I oversized some of the holes while removing them, so I ordered the next size rivets. Was an easy fix. In picture #3 you can see the bigger rivets (the 4 to the left) Also, I need to check, but I think I have the 8 screws in backwards (I think the screw head should be on the side showing, not the nuts. |
