Date:    2-5-2013
Number of Hours:    2.00
Brief Description:    Test Mounted HS
Aligned and test mounted the HS to the fuselage after balancing the Elevators with counter weights. No drilling at this point, I just wanted to see how it would fit in place, and it seems that it will not be a problem attatching it to the Fuselage. At this point I have decided to ad a VS extra brace to prevent any cracking in the mount. I will order it from smokinghole.com.
