Date:    10-18-2012
Number of Hours:    4.00
Brief Description:    Left Elevator
Finished the majority of the left elevator, excluding the Trim tab. I used Blind rivets this time on the spar for rivets that could not be reached by the Squeezer to avoid the mistake of over bending the elvator skin, I will fill the holes in the blind rivets with bondo to make a nice smooth surface, it should work well. Attached the counterballance arm and the Trim spar by just riveting the bottom half since the top will be attached to a hinge for the trim tab. also finished the trailing edge of the elevator as well. since it is much shorter I did not use pro seal when closing it up. it turned out ok but I see why now that it should be used on the longer trailing edges.
