Date:    1-31-2014
Number of Hours:    5.00
Brief Description:    Torque wings
Did the final torque on wing attaching hardware. Installed the 4 bolts as reminded by Van's SB and torqued. Installed rear spar bolts. Installed left wing tank bracket bolt and safety wired. Will need longer bold for right side tank bracked as I had to add a 3/16th spacer to get the angle bracket to match up with the fuselage alignment angle.
