1-23-2014 |
4.00 |
Aileron fitting |
I had to replace two rivets on each inboard aileron mounting bracket on the wing - both sides. I incorrectly had the flush end of the rivets on the inboard side of the brackets, not the outboard side. This created a slight rubbing on the aileron bracket attached to the aileron. Installed the small aileron pushrods and checked for movement. I am showing approximately 17 degrees down and 28 and 32 degrees up movement. Final adjustments to be made after wing installation. |
