11-15-2013 |
5.00 |
Wing wiring |
Installed Wiring and Angle of Attack tubing in wing for installation of a heated Pitot/AOA in the future if needed. Also checked electric trim operation. The 1 amp fuse would blow when I used the Ray Allen rocker switch on the center console. After checking the wiring, I called Tosten Mfg who make the stick grips. I was wanting to have the option of using the rocker switch for trim operation; as well as the hat switch on the grip. I found my anwer on the Van's Airforce forum and also on the Dynon forum. I had to remove 12v power from the rocker (black wire disconnected and red wire to aircraft ground). This makes the rock a grounding switch instead of a power switch. The rocker now operates the Tosten stick relay, just as the hat switch does. All works fine. Hung the VS, rudder and ailerons on the hangar walls to free up some workspace. |
