Date:    4-3-2014
Number of Hours:    6.00
Brief Description:    Torque check
Checked torque settings inside wing and fuselage. Checked fuel lines and re-tested torque on all connections. Applied torque paint to all.
I also painted the inside of the bottom cowl white for heat reflextion. I will be adding some heat reflecting tape where needed at hot spot areas.
