Date:    8-27-2013
Number of Hours:    6.00
Brief Description:    Rudder and HS tips
Fitted and installed the Rudder upper fiberglass tip and bottom cover. Also installed metal ring for taillite nav/strobe, which makes light removal much easier. Also fitted the VS tip; then did the initial fiberglass work to close up the tip. This will be finished to give a good clearance between the tip and the rudder.
