7-7-2013 |
9.00 |
Baffle Work |
Finished up trimming of metal baffles. Installed aft end and side material on trimmed baffles. I used a silicone rubber material from Aircraft Spruce It is supposed to be less abrasive on the inside of the fiberglass cowl under operation conditions. The material also is supposed to take a shape after flying for a few hours which will make taking the cowl on and off a little easier. |
