Date:    3-28-2013
Number of Hours:    5.50
Brief Description:    Baffle work
Spent the day match drilling, trimming, dimpling and riveting on some of the baffle parts. I also made the lower (inner and outer) 4 tension rods for the baffles.
Received the new mixture cable and installed that.
Mounted the fuel servo and attached the throttle and mixture cables.
Did some more wiring at the Master and Starter relays and also the manifold pressure system sensor.
