Date:    1-9-2013
Number of Hours:    8.00
Brief Description:    Side Skins rivet + wiring
These 8 hours were 3 short days combined. I first riveted the forward side skins to the upper longeron. Then I installed a bracket under the panel for the parking brake control rod. I removed the panel and proceeded to enlarge the center bulkhead cutout for wiring into the new audio panel installation. Pulled some more wiring.
Installed the center console which will hold the 12volt accessory plug, flap switch and trim switch and indicator.
