Date:    5-21-2012
Number of Hours:    5.00
Brief Description:    Miscellaneous
Made and installed the fuel line from the F.I. pump to the firewall. Installed a steel bulkhead/Firewall fitting for the fuel line pass through. Safety wired the pitch servo in the aft fuselage. Fabricated a couple of aluminum rudder cable fairings to cover the area where the rudder cables exit the aft section of the fuselage.
Moved the wings to Paul's Hangar (on my Birthday) for storage which will leave me room for the Finish Kit that is due around the 1st week in June.
I am sort of held up at this point until I pick up the Finish Kit.
