4-19-2012 |
6.00 |
Brake Lines, Pitch Servo Harness |
OK, I had see what it felt like. Installed brake lines from firewall, through center section and out to the exit fittings next to the gear leg mounts. I still have to mount the brake resevoir on the outside of the firewall and install lines to the M/Cylinders. I still need to install a fuel line through the firewall and then most of the brake and fuel line work will be finished under the front cover area. I also wired the pitch servo harness to the servo behind the baggage compartment. |
