2-29-2012 |
6.50 |
Pitch Servo |
Installed the Dynon pitch servo behind the baggage compartment; then removed it until final installation later. Installed some additional wiring tubes to carry wires/antenna wiring under and between cabin floor ribs. These would be from immediately behind the baggage compartment to immediately behind the control column. Also installed the two Van's static rivets in the side of the aft fuselage. |
