2-27-2012 |
12.00 |
Leg mount and Flap motor work |
Today I prepared all of the flap motor part, drilled, deburred, installed necessary nutplates. I installed the flap motor assembly, then removed all the parts and set aside for priming. I also made the hole in the bottom of the fuselage for the right leg mount and positioned it for mounting - then removed for now. Most of these items (control column, flap assembly, leg mounts will be reinstalled after painting the cockpit interior. |
