11-18-2012 |
2.50 |
Primed Rudder Skins |
Today I completed the priming by doing the Rudder skins. I ran through the same procedure as yesterday, however, it was very hot and windy today and as a result, the skins dried very fast. I should have increased the paint flow to reduce the speed at which it dried. Procedure was: Wipe down with Acetone to remove any oils. Wash in Stewarts EKoClean heavy duty cleaner. Rinse Soak in Stewarts Eko Etch solution for 3 minutes. Rinse Soak in a 33% solution of Alodine 1201 for as long as needed to bring up colour. Rinse Hang to Dry Spray with Stewarts Eko Prme using a 1.3mm nozzle in the DeVILBISS GTI-620G Millennium spray gun. The skins turned well |
