Date:    11-10-2012
Number of Hours:    3.00
Brief Description:    Deburing and Dimpling
I ran through each of the stiffeners, rib components, horn, the doublers and strikeplates and checked the edges and holes deburring as required. Having done all of tose, I started the process of dimpling. I started with the spar only to realise that there were about 20 holes that I had not final drilled. As a result, I had to re-cleco everything back together again just so I could do them. Ah well... on the positive side, I am getting a great right forearm from clecoing...
