2-19-2013 |
0.20 |
Prepare the Foam trailing Edge Ribs |
I used my printer scanner combo to make an exact copy of the original diagrams, just in case I needed to redo them later on. I cut them out and attached them to the foam blocks by using spray adhesive. I then cut them out on the band saw and trimed them on the linisher. |
