I was also very nervous about this step as it looks difficult to keep under control. Having said that, it is not nearly as hard as it looks. Once you have the distance of the skin from the edge of the table worked out, Put a big weight on the skin, lean on the bar and rivet away. The bar tends to not move sideways as it is on the edge of the table. Once you have the skin riveted in place at the TE, it is time to replace the clecos holding the ribs together with LP4-4s. No these went pretty well except after I was
