I dimpled the elevators in four sessions, each took about an hour. Unfortunately, I broke 2 repeat TWO dimple dies, both from Cleaveland. I came to the conclusion that my reasonably new CFrame from Avery was out of alignment, so I had a go at aligning it, but I have to say, the alignment looked to be around the axis that you can not adjust (The longitudinal axis). I had been using the CFrame with a steel ball peen hammer and a couple of days ago, my new dead blow hammers turned up. I happened to have my original Avery dimple die and coupled with the deadd blow hammer, it made it right through the two remaining skins without breaking, so ... Did the realignment fix it? The Avery die? or the softer impact hammer... Beats me. However, I got the task done
