Date:    7-12-2008
Number of Hours:    1.50
Brief Description:    center ribs and inboard and outboard ribs drilled
Marked the elevator ribs and cut L-angles for the center rib.
Marked and Drilled and cleko'd the L angles onto the elevator ribs.
Marked, drilled and cleko'd the center ribs to the Elevator center channel.
Inserted assembly into the elevator skin, and drilled the leading edge.
Marked and drilled the remaining ribs on the leading edge of the elevator.
