Date:    5-7-2008
Number of Hours:    1.50
Brief Description:    Drilled Ribs to Rear Spar and made 4 L - Angles
Calmped the rear Spar to the ribs (one at a time)
Drilled and cleco'd each rib to the rear spar.
Cut 4 75mm L angles out of the 4 ft L angle length. Rounded the corners with a flat file.
