Date:    1-10-2008
Number of Hours:    3.30
Brief Description:    Left L.E. and Tank Work
Re-assembled the left leading edge with clecos and squeezed the rear three rivets.
Cut the large holes in the inboard tank ribs for both tanks with the fly cutter.
Match drilled the tank access plates to the inboard ribs then match drilled the stiffiner rings to the ribs and drilled platenut holes in the rings and deburred.
