Date:    12-10-2007
Number of Hours:    3.00
Brief Description:    Rear Spar Assembly
Clecoed primed rear spar components together. Took an hour and a phone call to Van's to figure out which hole to rivet or not rivet. Matched drilled and dimpled the top holes in the two end doublers so that they will fit the main spar holes that are dimpled.
Also ran the scotchbright wheel over several more ribs.
