Date:    2-11-2006
Number of Hours:    1.00
Brief Description:    Bagan installing alternator and filled coolant
Filled coolant and made a mess, then the radiator plug started leaking. Now I have to take the radiator off and drain so that I can fix the plug. FIlled oil resv. Started installing alternator and ran into a problem fitting one of the arms, so I stopped and called the factory later.
