Date:    2-18-2006
Number of Hours:    2.00
Brief Description:    pulled radiator, attempted to install prop and alt
Removed radioator to find get at radiator p;ug which was leaking. FOund out that the plug was never tightened, whoops. Used teflon tape and silicon sealant to seal the plug, left to dry over night. Drilled out alternator bracket so that it would fit correctly. Assembled prop and prop hub and tryed to install on the prop shaft. The bolts supplied with the prop were not long enough because the alternator puilley increased the thickness of the prop flange assembly. Gotta get longer bolts.
