10-3-1999 |
8.00 |
Right wing ribs |
Drilled out the inboard lower sheeted rib and replaced with the new redesigned rib recently sent from the factory. Installed the outboard lower sheeted rib which required some grinding of the rib to fit it around the already installed rivets that hold the |
