Date:    4-1-2001
Number of Hours:    7.00
Brief Description:    Wiring
Wiring. Tested positive and negative wiring for the following: warning lights, interior foot lights, GPS, radio, intercom, OAT probe, transponder 2 encoder, EIS, master switch, master avionics, ground bars, PTT switch, trim indicator, and reostat. Tested OAT connection to EIS. Filled mistaken hole in slip indicator. Drilled slot in back of panel for wires.
