Date:    9-2-2006
Number of Hours:    9.00
Brief Description:    Center cover and BRS
Worked on installing the BRS. Created a bracket extension out of aluminum bar. Made a replacement bracket for the front
attach point of the BRS but had to scrap it when it bent upon tightening it down. I then had to force the original bracket into place
with trusty hammer. I also filed down the top of the fuel cut off lever. Cut slits in front center cover for the BRS bracket .Drilled
more holes in center cover and clecoed. Assembled rocket motor.
