9-11-2009 |
3.00 |
Drilling (Cont.) |
Continue to drill the sheet metal tags (25 pieces) , engine mount, metal washer and the trim metal plate. Other then the metal tag, pilot hole was firstly drilled before the actual hole sizing. The engine mount was later drilled using 3/8" drill bit and the trim metal plate using a 1/4" drill bit. The washer require a 3/4" drill bits and this will be done at a later date. |
