Date:    12-26-2007
Number of Hours:    1.50
Brief Description:    Tail alignment
To ensure the vertical stab is at its proper location an alignment was made many times using firewall stn 0, at both top and bottom of the firewall, and adjusting the plywood jig at the tail end.
Once the vertcal stab was in position, the tail end longeron was then shaped to fit with the vertical stab. The bottom tail end needs some bending. Heating it up might be required.
