5-22-2004 |
3.00 |
Fuselage Tail Area |
Work on the horizonal tube connecting both frame which earlier was found to be a bit short. It takes quite a while to trim both end. Check the diagonal tube at sta 115 3/8 to ensure a good fitting. After checking it does not look very satisfactory. Cut another tube and trimming at one end done. |
