Date:    2-8-2004
Number of Hours:    1.50
Brief Description:    Longeron Adjustment
The diagonal longeron for the aft cockpit floor was clamped for a proper fitting with the horizontal tube. The upper horizontal tube for the backseat was aligned and then properly set. A wooden block was nailed to the table top to hold the tube when tack weld. The tube to hold the control for the aileron which had fall off due to bad tacking is put back with the use of two wooden block clamp with the C Clamp. The back vertical tube that has dislodge will be re align sometime next week.
