Date:    1-25-2004
Number of Hours:    8.10
Brief Description:    Cockpit Area Tube Fitting
A diagonal tube for the aft cockpit floor was done and with difficulty it fit. The vertical diagonal tube behind the cockpit area was trim and again with much difficulty it fit. Adjustment between this vertical tube and the horizontal diagonal tube took sometime for a good fit. Proceeded with cutting a tube and fitted a short diagonal for the aft cockpit floor. The shorter diagonal among the two need further trimming.
