11-6-2010 |
4.50 |
7129 ELT bracket, Pitot static tube, rudder cables |
Finished priming and installing the 7129 ELT bracket. Installed the pitot static source on the back of the plane. Installed the hollow rivets, and the tubing up to the T fitting where it will travel up to the panel. I don't want to finish the tubing until I have more of the plane finished. Also ran the rudder cables. Movin along. Seems like i got alot done today. You need those days every once in a while. |
