Clecoed 2 HS - 1004 Ribs to HS - 00916 Stringer web. Set up the squeezer and squeezed them with rivets called out in the drawings. Then clecoed HS - 00914 Stringers. Rivets called out in the drawing are too short. Cut AN470AD4-5 rivets to 4.5 then riveted starting from the middle working towards the edges. 4 rivets on the corners used rivet gun to set. Almost was a disaster when dad ran a rivet gun. He made a mark on the web but should be fine. On March 29 found out that 2 HS-1004 ribs were reversed, so i will have to dimple the bottom holes and flatten the dimples on top.
