1-29-2015 |
2.50 |
Clecoed together Stringer web assembly |
Clecoed together stringer web assembly and dryfitted it into front spar. Noticed that two tabs on the modified inspar ribs didn'tfit correctly into stringers becuase they sit on the angle. Filed down inside of the tab in placed slight bend with hand seamer until it fit good. Second rib I only placed the bend in the tab until it fit good. Now both tabs sit flat inside the stringer. Started c-sinking front spar setting depth 0.009" deeper than flush rivet. |
