Date:    10-15-2014
Number of Hours:    2.00
Brief Description:    Step #1-3 Working and Spar and Doubler
1.5 hours to finish deburring Spar. Clecoed doubler to the spar. Marked area that will not be riveted with DNR. Final Drilled #30 all common 1/8 holes to the spar and doubler. Match drilled 1/8" 4 holes from the spar to the dubler, then reamed with #30 reamer.
