2-10-2015 |
2.25 |
Steps #3-6 Reaming and disassembling rudder |
Final reamed all holes common to skin and trailing edge using #41 reamer, as per drawings started in the middle of the span, reamed and clecoed every hole. Then final reamed all holes common to R-903 tip rib and R-912 Counterbalance rib. Match drilled 3/32 t hole in the forward flange of the L skin into R skin then reamed with #41 reamer. Completely disassembled rudder assembly. |
