Date:    5-11-2014
Number of Hours:    1.75
Brief Description:    Step 2, 5, 4 Separating and Deburing
Finished cleaning stiffeneres. Separated bottom rib with hack saw. Had to use blade without handle for inner tabs. Used CP wheel to grind down the tabs, then used file to smooth them out. To clean remaing part used soft wheel.Removed hatched areas on the Horn Brace. Cleaned it up with file and wheels.
