Date:    5-6-2014
Number of Hours:    1.00
Brief Description:    Step 2 Separating stiffeners
Separated all stiffeners into left and right. Marked all parts and hatched areas to remove. Removed extra material with snops about 1/8 of the inch from the line. Using cut and polish wheel removed remaining material. Debured heavy burs with cut and polish and cleaned them up with soft wheel. Debured all holes. When I was cleaning up R-00915G-1 on the soft wheel part sliped and got cought between the wheel and the support and got damaged. I WAS VERY UPSET!!! Removed support on the bench grinder and continued deburing. Next day ordered new part from vans.
