Date:    11-27-2008
Number of Hours:    0.00
Brief Description:    Grease fitting on the 7/8x058 slip fit flap contro
Found Marks reply to Wayne which pretty much covers the issue for me. I will build as per plans and not add grease fittings. If it works for the QB and Bob then I will trust that it will work well
enough for me.
--- In Bearhawk@yahoogroups.com, "n95mf" wrote:
> The kits don't have grease fittings on those parts. I lubricate at
> annual or more often if the plane has been outside in the weather. Mark
> --- In Bearhawk@yahoogroups.com, "Wayne Massey" wrote:
>> I've run into a problem and I'm wondering if anyone else has run
> into this and what was the correction. I positioned the grease
> fittings on the flap torque tube bearings on the flap support frames
> and the root support tubes to the down position. After making the
> parts I temporarily fit them to the rear spar and I now see that the
> grease fitting in each application is going to protrude beyond the
> bottom skin. It looks to me that these should have been positioned to
> the rear.
- Hide quoted text -
--- In Bearhawk@yahoogroups.com, "Jeff Page" wrote:
> I'm working on my wing steel parts. While test fitting the up the
> flap drive linkage with the wing root flap support assembly it
> occurred to me that the Patrol plans do not call for a grease fitting
> on the 7/8x058 slip fit supports. How do they stay free from rust?
> Regular oiling?
> -jeff page
> Patrol #042
> Windsor Vt
> http://www.mykitlog.com/orrem31
