9-11-2008 |
0.25 |
Thoughts on options |
Thoughts on options Mandatory VFR Instrumentation/Equipment (FAR Part 91) - Airspeed Indicator - Altimeter - Compass - Tachometer - Oil Pressure Gauge - Oil Temperature Gauge - Fuel Quantity Indicator (need not be an instrument) - ELT - Seat Belts Required for operation - Master Switch - Ignition Switch - Primer - Throttle - Mixture Control - Carb Heat - Fuel Shutoff - Elevator Trim - Voltage Meter - Outside Air Vent - Cabin Heat - Fire Extinguisher Stuff I defiantly want - Garmin 396 - Slip/Skid Ball - Radio - Intercom - PTT on sticks Stuff still under consideration - Transponder - Rate of Climb Indicator - Nav Lights - Strobe Lights - Beacon - Landing Light - Taxi Light - Beacon Strobe - Stall Horn or Lift Reserve Indicator Stuff I have ruled out - IFR Instrumentation - Autopilot - Tail Hook for Hand-Propping - Accelerometer ("G" Meter) - Cabin Lights |
