Date:    10-20-2016
Number of Hours:    3.00
Brief Description:    Right wing
Left wing is done so I immediately move on to the right one.
Bolt it on, set the dihedral, cut the struts to length, drill the attachment fittings and bolt them, bolt on the front strut, set the washout and then bolt on the rear strut. Having done it previously on the left wing in 5 hours, the learned process only took 3 hours this time around.
